Hardware Features
Programmable Logic Device: Altera EP2C5 FPGA
4608 Logic Elements
119.8Kb User Flash Memory
I/O:
74 digital I/O
Full Arduino PB/PC/PD Connector Coverage
6, 8-Bit, 3.3V powered, Digilent PMod Compatible I/O Docks
Altera Signal-Tap Embedded Logic Analyzer Enabled
Analog Capable via Pulse-Width and Delta-Sigma Modulation
1 Push-button input/Arduino Reset
1 Dedicated Controllable LEDs
Dedicated JTAG In-System Programming Port
Dedicated Active Serial Programming Port
Board stackable with Arduino, Amani, and other compatible shields
DB1/DB2 pads provide 30 I/O and 3 voltage options to daughter cards
Clocking:
Comes Standard with 64MHz Oscillator
Additional clock can be supplied by Arduino
Off-Board clocks available via Digital I/O
Power:
On-board 3.3V Regulator Can be powered by:
J1 Off-Board Power Connector
Arduino 5V JPower Input
Board may be powered by Arduino 3.3V JPower Input
Board can provide power to Arduino and other shields via Vaux Connection
User Options:
2 x 30-pin header space open for easy prototyping
EPCS1 flash memory pad
Active Serial programming port header space
