Blinking wearable
This is the story of a blinking device that I built as a Proof of Value (PoV), from the concept to the real device.
0 followers
I had to build a blinking device as a Proof of Value (PoV).<br><br>The concept is quite simple:<br>* The device should blink in green during 2 hours,<br>* After two hours, the device should blink in red,<br>* After two more hours, the device should stop blinking,<br>* The time counter can be reset with a magnet near the device.<br>* The device had to be as small as possible, as it should be wear and visible.<br><br>I chose the components, made the PCB layout, write the code, and built the case with my 3D printer.<br><br>You can read the full blog post and get the source code here:<br><a target="_blank" rel="noopener noreferrer" href="https://www.iot-experiments.com/blinking-wearable/">https://www.iot-experiments.com/blinking-wearable/</a>
  • 1 × ATtiny13A Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 5050 RGB LED
  • 3 × 100 Ohm resistors
  • 1 × CR2032 Batteries and Battery Accessories / Batteries
  • 1 × Capacitor 10µF
View all 7 components
Starhawk wrote 04/07/2020 at 22:55 • point
The point of Hackaday[dot]IO is to serve as a repository for projects. If you've got a writeup elsewhere, at least do us the dignity of copying it over. You've kind of started already -- there's pictures here and a list of components... but the reason behind this device and any sort of build instructions or development logs are missing. Might want to look to that ;) normally I don't mind the idea of a "more info here" link, but this is one case where it's really not the best way to handle that.
