A compile-in (C, C++) solution for reading key-value pairs from file(s), looking up settings, and writing a config file back to disk.
There is no standard way in C to parse config files. Several libraries have sprung up to solve the problem, but perhaps that is overkill for what should be a simple operation.
Presenting: cfg_parse - a compile-in solution for reading key-value pairs from file(s), looking up settings, and writing a config file back to disk.
There is full documentation on the Sourceforge page. Project gave me a good opportunity to try out Doxygen, which I like a lot.
Typically, a user should create a pointer to a cfg_struct, initialize it with cfg_init(), and then perform actions on that object (lookup, add, delete) by passing the pointer to the functions here. At end of use, call cfg_delete to clean up the object.
Sample code:
/* driver test program for cfg_parse */
#include "cfg_parse.h"
#include <stdio.h>
int main()
  /* Pointer to a cfg_struct structure */
  struct cfg_struct *cfg;
  /* Initialize config struct */
  cfg = cfg_init();
  /* Specifying some defaults */
  /* "Required" file */
  if (cfg_load(cfg,"config.ini") < 0)
    fprintf(stderr,"Unable to load cfg.ini\n");
    return -1;
  /* Several "optional" files can be added as well
      Each subsequent call upserts values already in
      the cfg structure. */
  /* Retrieve the value for key INFINITY, and print */
  printf("INFINITY = %s\n",cfg_get(cfg,"INFINITY"));
  /* Retrieve the value for key "KEY", and print */
  printf("KEY = %s\n",cfg_get(cfg,"KEY"));
  /* Delete the key-value pair for "DELETE_ME" */
  /* Dump cfg-struct to disk. */
  /* All done, clean up. */
  return 0;
  • Updated to 1.0r6
    Greg Kennedy04/21/2015 at 17:02 0 comments
    The only difference between this and r5 is the addition of extern "C" in the header file. This enables usage within C++ projects.
  • Updated to 1.0r5
    Greg Kennedy08/28/2014 at 23:21 0 comments
    Just a little source cleanup for the latest release.  This is very stable and I use it in lots of my hobby projects now.
    You can either download the zip file with code, or add it as a svn:externals property to automatically stay up-to-date.  A sample line would be:
    svn propset svn:externals "cfg_parse svn://" .
View all 2 project logs
