Technical Specifications:
Processor : MK20DX256VLH7
-Cortex-M4
-Clock speed : 72 MHz
-Overclockable to 96 Mhz
Power requirements:
-2.8 to 5.7 Volts
-26 mA (at full power)
-10 uA (sleep mode)
-Can be USB powered using USB programming shield
Flash Memory : 256 Kb (192 Kb available after Aurbee stack)
-192 Mb/sec Bandwidth
-256 bytes Cache
Ram: 64 Kb (52 Kb available after Aurbee stack)
EEPROM : 2 Kb
Direct Memory Access : 16 channels
Digital I/O: 34 pins
-Output: 3.3 Volts
-Input : 5 Volt Tolerance
Analog Input : 21 pins
-2 converters with 16-bit resolution (13-bit usable)
-2 Progressive Gain Amp
-12 touch sensing pins
-3 Comparators
Analog Output : 1 pin
-12 bit DAC resolution
Timers: 12 total
-3 FTM with 12 PWM output pins
-1 PDB
-1 CMT (infrared)
-1 LPTMR
-4 PIT (interval)
-1 Systick
-RTC (date/time) requires a 32.768 kHz crystal & 3Vbattery.
Communication: 1 USB
-3 Serial ports with 2 FIFOs,3 High Res Baud,2 Fast clocks
-1 SPI with 1 FIFO
-2 I2Cs
-1 CAN Bus
-I2S Audio 8 FIFO
liz
Paul Andrews
Alain Pannetrat
Michele Perla
