Very little progress
A project log for M5Stack - An Open Source Enclosed Modular Toolkit
M5Stack is a robust, open source development kit with stackable modules, user-friendly IDE, enabling rapid and high-quality prototyping
jimmylaiJimmyLai 09/14/2016 at 05:160 Comments
Adding conductive structure
The most important value for M5 is its stackable that it could link up multiple functional modules to fulfill your requirement, in a simple and elegant way. But M5 is yet not perfect. a pain point is in the stacking process, we use standard 2.54mm pin as the connector. You may ask that why not use some sort of touch spot? The reason is that it is hard to find those conponents with low cost and high quality(sustainable).
The conductive structure, set by bolt around the corners, has been tested,eventually fixed the problem and brings awesome user experience. XD
