Customize your smart life
02/10/2017 at 09:42 • 0 commentsWe use the M5 Matrix module to make a GPS tracker for the bike. And this prototype can work with other device in the house, whenever I come home, the door can open automatically.
This is one of our scenario for the smart life. All the devices around us can be updated to work together wirelessly. And we can customize our devices which will be different from all you can buy in the market, but they will be more convenient and effective.
M5Stack - What if the Arduino with a case
02/09/2017 at 09:12 • 0 commentsWhat if the Arduino with a case? We get fun from a easy and smart world.
Introducing Auto drill machine
09/20/2016 at 04:07 • 1 commentThis is the industrial machine prototype which aims to help people drilling remotely. Drilling could dangerous, under several situations like gas, High voltage cables, will course huge damage.
The whole machine was M5 embedded and design under M5's open standard.
Very little progress
09/14/2016 at 05:16 • 0 commentsAdding conductive structure
The most important value for M5 is its stackable that it could link up multiple functional modules to fulfill your requirement, in a simple and elegant way. But M5 is yet not perfect. a pain point is in the stacking process, we use standard 2.54mm pin as the connector. You may ask that why not use some sort of touch spot? The reason is that it is hard to find those conponents with low cost and high quality(sustainable).
The conductive structure, set by bolt around the corners, has been tested,eventually fixed the problem and brings awesome user experience. XD
