Retrospective: Earlier model (sort of)
A project log for Reactron energizer: Interruptible Power Supply
A UPS modified such that power ports are individually controllable, via wireless RF network commands
kenji-larsenKenji Larsen 06/16/2014 at 03:180 Comments
Here's essentially the same thing but with only one port, and no UPS.  It is basically just a wireless 120VAC relay with a manual override (the switch).  The case is just a regular blue PVC electrical box.  Simple, but served me well for a long time.
The relay board is just visible inside, without taking it all apart to photograph it....
This worked well, but I do like the UPS on the microcontroller.  Of course, this whole small unit could be plugged into a regular UPS.  Still, it only had one port (the two outlets are bridged).
