Log Entry #7 : Sensor processor complete (mostly)
A project log for Remote Water Consumption Display
Design and build a simple, inexpensive, and manufacturable remote indicator for the most common type of mechanical water meter in use today.
john-schuchJohn Schuch 09/21/2014 at 06:330 Comments
As you'll see in the video below, I have most of the firmware for the sensor/transmitter module complete. All I have left to do is remove the code used to drive the LCD display (which is only used for code development and debugging), and redirect the serial output to the transmitter module. Then a couple hours to move the components from a breadboard to the PCB proto area of the microcontroller development board. With those done, the sensor/transmitter module will be complete.
With the transmitter complete, I can turn my attention to the receiver and display system. I have most of the hardware put together and working, now I'll be able to receive the sensor pulses via the radio link and actually work with real data.
I can now see light at the end of the tunnel. :-)
