Early prototype ready
A project log for Little Mister
A heavy duty flashlight for special occasions.
Ole Andreas UtstumoOle Andreas Utstumo 09/09/2016 at 23:540 Comments
100W of LED mounted on a cooling rib, with a 120mm fan, a 100W LED driver, a 22.2V li-ion pack and a simple ON/OFF switch on the back.
100W white LED on Aliexpress
LED driver on Aliexpress
The output as seen slightly out of focus:
Not nearly enough.
