Heatsinks bolted in place
A project log for Little Mister
A heavy duty flashlight for special occasions.
Ole Andreas UtstumoOle Andreas Utstumo 12/06/2016 at 10:350 Comments
The mounting holes used to screw the heatsinks to the frame were drilled with a 3.5mm drill bit, and M4 screws were screwed in place with force.
The light feels pretty damn sturdy.
A thermistor soon to be buried with thermal paste in the ridge of a heatsink to monitor the temperature for fan control.
