Securing the electronics
A project log for Little Mister
A heavy duty flashlight for special occasions.
Ole Andreas UtstumoOle Andreas Utstumo 01/20/2017 at 07:150 Comments
There are a lot of legs from through hole components poking out on the backside of the LED drivers, so I will put these on acrylic glass, mounted in a fashion you can see underneath. The DC/DC converters for the fans get pretty hot, so they will be mounted on a aluminium length using thermal adhesive. The ruler is just a substitute ;)
There should be plenty of space for the control board.
