SMART HOME AUTOMATION USING ARDUINO
a home automation system using a simple Android app, which you can use to control electrical appliances
Public Chat
Nowadays, people have smartphones with them all the time. So it makes sense to use these to control home appliances. Presented here is a home automation system using a simple Android app, which you can use to control electrical appliances with clicks Commands are sent via Bluetooth to Arduino Uno.
Zip Archive - 4.35 MB - 04/19/2018 at 02:25
Download
Zip Archive - 863.26 kB - 04/19/2018 at 02:25
Download
Zip Archive - 482.00 bytes - 04/19/2018 at 02:25
Download
  • 1 × arduino uno
  • 1 × relay board
  • 1 × wires
  • 1 × bluetooth hc-05
  • 1 × fan,tubelight,cfl,light
  • 1
    Relay Connecting With Arduino
    .It is a simple project and but its also very dangerous ...
    because we are going to deal with high voltage 220v . Do not attempt if you are a amateur in dealing with high voltage.
    Why to use relay for controlling AC light,fan and other appliances...
    AC is alternating current 220v (india) which powers the ac lights,fans,cfl ets.... Arduino cannot control high volt n amp, but a relay can do this job, which is the sole design of it.
    so we are using relay as switch to control high power devices.
    What is NO NC and COM in relay?
    C = Common Connection
    NC = Normally Closed Connection
    Picture of Relay Connecting With Arduino
  • 2
    Set Up Circuit Using Relay,arduino and Bluetooth
    here is connection...
    bluetooth is connect to arduino in tx and rx pin...
    we have to connect all appliances to relay board.....
    one relay board for one lights,then 2nd for CFL,3rd for fan and 4th relay for tubelight....
    thats it....
    Picture of Set Up Circuit Using Relay,arduino and BluetoothPicture of Set Up Circuit Using Relay,arduino and Bluetooth
  • 3
    Connect App With Bluetooth
    this is the screenshot of the app...which is made by mit app inventor..
    download the app link description below ..
    install it in your phone..and connect it with hc-05 bluetooth module..
    thats it...
    Picture of Connect App With Bluetooth
View all 4 instructions
