The fail
A project log for Deep Foundation Laser Scanner
This project try get the dimensions about a deep foundation without a danger to the responsible for the excavation survey.
laio-athos-nevar-fonsecaLaio Athos Nevar Fonseca 10/30/2018 at 02:301 Comment
Yes! That's a good pic. But i have some problems on the voltage to the robot.
I used 12v but I make a mistake on the wiring. So, I didn't make the test.
In the next week I will try make a new test.
Mike Szczys wrote 11/29/2018 at 15:26 point
It's exciting to see you testing out prototypes! I'm looking forward to seeing the results of these tests.
