Hackaday.io Hackaday.io
Sign up Log in
Fab@Home Model 2 Conversion
Converting a Fab@Home Model 2 to be a large surface printer and CNC machine using modern motors and electronics
samernsamern
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
32 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
441
0
32
2
Team (1)
  • samernsamern
Join this project's team
Fab@Home 2 Big 3D Printer
This project was created on 06/14/2014 and last updated 11 years ago.
Description
My very first printer was a paste spewing Fab@Home Model 2. I enjoyed building it and learned a lot. But when the project was abandoned, I was dismayed, especially since I was able to briefly run it as a CNC machine. The problem was always the proprietary motors and controller. I hated that. So I converted mine to use ordinary steppers and a Sanguinolou board. I am still working out print heads but I've solved the linear motion problems. I am also converting out of belts to use leadscrews which give smoother more predictable motion.
Project Logs
Collapse
  • Project on hold
    samern • 10/25/2015 at 13:56 • 0 comments
    Now that I have a printer farm, I have set this project aside to work on my 3-in-1.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The stock toolhead/carriage is replaced with a modular system that allows quick and easy toolhead changes.
Project Owner Contributor
Monoprice Select Mini V2 Modular Toolhead
mc88MC88
3D Printer using upcycled CD drives, hard drives, and an ATX power supply.
Poor Man's Mini 3D Printer
accidentalrebelAccidentalRebel
Add sheet metal panels to your project almost for free.
Enclosure for Projects based on Ikea Vårsyren
julius-curtJulius Curt
Supplyframe DesignLab: 2022 Hackada…
It’s getting hard and expensive to get components. We're developing a system to automatically deconstruct old products for recycling/reuse.
The Disassembler by team Table Flip
johnJohn
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Fab@Home Model 2 Conversion", please tell us the reason.
Send message
Remove Member
