X Y calculations
A project log for Simple & Cheaper CNC Shaper
I love the Shaper Origin, it could solve many needs for the home maker and care taker. But at the price many can't afford it.
konkopkonkop 09/13/2016 at 12:090 Comments
It looks like the XY calculations are quite easy. Its called forward kinematics and can be seen calculated here https://www.marginallyclever.com/2012/02/drawbot-overview/. Next I have to do interrupts on the encoder rotation to make sure I get every tick. For version 0 I think I'm going to put the encoders on the work surface and weights on the belt like a draw bot for simplicity. Then all I need is power to the drill and z stepper. For v0 the electronics will be kept off the shaper and won't have auto correct .
