Using mice for X Y offset
A project log for Simple & Cheaper CNC Shaper
I love the Shaper Origin, it could solve many needs for the home maker and care taker. But at the price many can't afford it.
konkopkonkop 09/14/2016 at 18:380 Comments
In further investigation (thanks to PointyOintment's suggestion) it may be simpler to use multiple PS2 mice instead of the belts. You can do deadest reckoning with two mice read http://www.instructables.com/id/Optical-Mouse-Odometer-for-Arduino-Robot/step4/Further-Modifications-and-Finishing-Up/ and https://www.researchgate.net/publication/221645389_Dead_Reckoning_for_Mobile_Robots_Using_Two_Optical_Mice. But this always assumes you haven't cut large lines out of your working surface. This means many mice would have to be used and ignore the extreame values.
