Low Fuses
A project log for MagSpoofPI
Be able to make & upload MagSpoof with variable tracks, to use it without Arduino dependencies, and implement it on the same Raspberry GPIO.
salvador-mendozaSalvador Mendoza 09/20/2016 at 00:020 Comments
I had some issues with the low fuses some time ago. I was trying to upload the MagSpoofPI code using the low fuses for 8mhz(0xe2) in the makefile. It won't run, keep 0x62 for low fuses.
