Dumping WIP
A project log for 74xx Hamamatsu S6986
An attempted to build the Hamamatsu S6986 Light Modulation Photo IC from commonly available discrete components.
morganmorgan 09/13/2016 at 19:040 Comments
I've added a link to the fantastic Light Modulation IC reference from Hamamatsu (hosted on pobot.org), this is the guide which I'm designing my circuit against.
I've also published the KiCad project and schematic files for my work so far. Bear in mind there is a lot of hand wavyness going on for several reasons.
Firstly I haven't put much consideration into component selection as I'm starting by trying to flush out as much of each stage as I can. So the components in each stage are not likely to be ideal.
Other very vague parts include the LED Driver block, the "D" and "U" signals as I don't have a complete understanding of how these stages work yet.
