Rain/Water Resistance Test
A project log for Solar Powered Mobile Device Charging Hat
Solar cells in the hat charge an internal LiFePO4 battery, which can then charge any mobile device via USB
msummers123msummers123 09/15/2016 at 18:450 Comments
I took a hat with the solar cell trays installed and left it in the rain for a few hours, letting it get nice and soaked. I then tested to ensure it still worked, which it did. You can see the video below:
I'm still waiting on the new battery charging system and enclosure, once that is done I can test that as well. But at least the solar cells work in the rain.
