Log 4: Time to start cutting
A project log for Solar Analemma Chandelier
A chandelier of LEDs, WiFi and CNC'd MDF.
doigaldoigal 04/22/2018 at 19:530 Comments
Before committing to a large block of wood (and the milling time required to cut it) , I wanted to do a few test blocks to properly get the right parameters for tooling, materials, finishing, etc.
The idea with the first one was to check the different machining processes - would the 0.8mm endmill or the v engraver work better, size of the text be OK, make sure the edges come out clean, etc. A difference operation in Fusion gave me a small section that was going to tell me what I needed:
An hour of CNCing later at MakersLink, and I got this:
So what did I learn?
