One of the things that's bothered me about the hardware on the arm floats is that it doesn't always provide the smoothest edges. The bolts are a good example of this. While it's by no means a rough edge, these bolts stick way up and don't blend in well with the rest of the arm floats. Basically, it's functional, but kinda ugly and does pose a small risk of things bumping/ snagging on it.
A better option seems to be button head bolts.
Here you can see it in context:
This is definitely an upgrade on my backlog. So far, I've only upgraded a couple bolts when I've had broken plastic pieces that have needed repair.
