Testing analog in/out
A project log for Electronic pressure regulator
Closed-loop air pressure control that can talk to a microcontroller
craig-watsonCraig Watson 06/01/2018 at 19:190 Comments
I just added support for analog input & output, i.e. setting the setpoint and reading the current pressure via two pins with voltages between 0 and 3.3V.
To test this, I used a Teensy 3.2 as the "master". A rotary encoder and LCD makes it easy to change the setpoint and view it and the measured pressure. This particular pressure regulator can manage 0-30 psi, so setting a voltage of 1V on the "SP" pin would request a pressure of 10 psi.
Here's what the test setup looked like:
The power input is 12V, which supplies both the pressure regulator and the pump on the left. The output of the regulator is hooked up to a pressure gauge, for easy validation.
I also monitored the regulator via USB. With only P/I control, the results are already pretty good:
There is some overshoot upon large changes in setpoints, but nothing too dramatic. The pressure doesn't oscillate, and it can easily follow small changes in setpoints.
I did have to smooth the analog setpoint measurement, as there was some noise in the signal. It would vary by ~ 1% of the ADC range. So to counteract that, I average out several successive readings, and also only consider changes of >10/1023 to be an actual change in setpoint.
Without this correction, the graph looked like this:
Still pretty good, but this leads to unnecessary adjusting of the output, which wastes quite a bit of air.
Next up: i2c!
