Made the structure for the dancing petals!
A project log for Formapale Edest
Beautifully Deceptive Eater
bhavesh-kakwaniBhavesh Kakwani • 04/20/2018 at 20:05•0 Comments
Good progress has been made on the plant's structure and its "dancing" petals! Here's how Natalie did it.
Start by drilling a hole in the side of a dowel so that your metal rod can fit though.Then you want to spin the rod around in a circle and glue it into the hole - this circle will be the central anchor point for all our petals:
Then, get down and dirty and mold the chicken wire with you hands to make the plant's stem!
With that in place, you should have a better idea of where the petal anchor point is going to be on the stem. So let's get back to the anchor - start by making the first petal. It's basically a dowel that's attached to the anchor by twine and a generous helping of hot glue.
Let's put it in the structure and see if it's able to move back and forth like we want. It turns out, it has too much freedom to move back and forth in those huge hexagons of the chicken wire! So, Natalie cut off two more small lengths of dowel and glued them to the chicken wire as a pivot point for the main petal dowel:
Rinse and repeat that for the other 7 petals, and you'll have finished your initial structure! Always make sure that the central anchor is in the centre of the stem's opening! Or not...I guess it's not a big deal because you can always mold the chicken wire after the fact to the shape that you want.
That's it! Enjoy poking it back and forth and see if you are getting the range of motion that you would be happy with. Also account for the fact that once the petals are put on these dowels, they are going to be much heavier and hence more difficult for the motor to move them. So, err on the high side for how large a range of motion of the petals you want to see at this stage of the build.
