Further ADC Noise Reduction in Firmware
A project log for Car Battery Monitor
Monitor the voltage of a 12V car battery in order to get early warning that the battery is becoming discharged
chrisChris 09/24/2016 at 01:200 Comments
Using averaging in firmware has made the readings less noisy (see graph after 19th Sept) , so I am going to switch to the 'Averaging of N-X ADC samples' technique described in the application note, to see if it results in a further improvement.
