Rewiring the panels and adding temp sensors.
A project log for SAM - Solar Automation Machine.
Sun Tracking, Charging, Cooling , Monitoring, Relay control. for my small solar panel installation.
EmericaEmerica 08/17/2014 at 04:580 Comments
The lawn crew chewed up my wires, time to re-wire.
8ga wiring everywhere, nice connectors and it's now all loomed. They will have a harder time crewing through that.
The temp sensors were also hot glued to the back of the panels and wired with cat-6.
And hot glue on glass that gets hot = fail., the temp sensors fell off on the first day back outside.
