> monitoring the front door <
A project log for DIY SCADA / smart home
A DIY smart home system the SCADA way...
stefanschnitzerstefan.schnitzer 10/12/2019 at 06:090 Comments
I never wanted to control the door lock via my smart-home system.
It always seemed too risky.
So I added the capability to only monitor the state of the front door (open/closed) and the lock of the door (locked/unlocked).
The door state is monitored with a magnet and reed switch combination, the lock via an inductive proximity switch on the frame.
The states are captured with my Arduino remote I/O
(https://hackaday.io/project/167904-diy-scada-wireless-remote-io)
and sent to the software PLC.
The inductive proximity switch can sense the latch through the wood of the door frame.
A 3d-printed part and hot glue hold it in place.(no drilling required)
