Thumb joint and finger base
A project log for Soft-Handy
This project is an exploration of a pneumatic artificial hand that could be used for a robot or as a prosthesis.
Nelson PhillipsNelson Phillips 09/26/2016 at 12:250 Comments
The thumb is a clearly an important component of hand function the two fingers and thumb picture below shows an early solution. It revealed that there requires an angle on the apposing joint and the third joint is a difficult to straighten from being parallel to the fingers.
So the following two pictures show the angle and joint in detail. The two hinged joint, carried from earlier, is less restrictive and was able to provide a little more strength here.
The actuator for the thumb base joint, below, is large and provides the force to keep it stable, using the commonly used, for this project, flexure equation
Most of the CAD model has been completed for this stage of the project and requires construction.
