Major Milestone
A project log for OpenBLDC
BLDC shield for arduino and stand alone controller
nerdkingnerd.king 06/12/2017 at 00:300 Comments
I have built up a couple of the new boards. I figured out a flaw with the voltage regulator circuit and swapped out that part.
This makes the whole board a lot more stable.
Using a power supply, I was able to get the hub motor spinning both in forward and reverse.
