I made a YouTube video about this entire project:
I had seen this video from Maker's Muse: which gave me the inspiration for the solution to my problem. By utilizing the cubic lattice structure that can be modeled in Meshmixer, I have been able to make 3D printed bouncy balls that bounce better than the original (plain and spherical).
Here are my results:
Version 1: This was the first attempt at using a 3D cubic lattice to improve bounciness. It was very dense and too hard. It had a wall thickness of 2mm, a tube thickness of 3mm, and a density of 7.5mm.
Version 2: This was the second try using the cubic lattice. It produced great results. It was not too dense, bounced very well, and bounced consistently. It had 4mm wall thickness, 4mm tube thickness, and 10mm density. On average, it bounces 3' 9".
Version 3: The third attempt yielded worse results than the previous one. It bounced less, (averaging 3' 4") and less consistently. It had a 3mm wall thickness, a 3mm tube thickness, and a 18mm density.
Expansion and further information:
Upon further investigation, I found that there is a fundamental limit to how "consistently bouncy" a 3D printed structure can be. This is a result of 3D printed flexible materials being more elastic in parallel with the layer lines. This results in the ball bouncing best when it's layers are parallel with the surface it is bouncing off of. Paradoxically, 3D printing is the only manufacturing technology that can make this geometry, making this limit unavoidable.
This knowledge, along with the designs and information of the project itself could have many applications in controlled compliancy and metamaterials. If the density of the lattice were to be different throughout a 3D object, the finished print would have varying compliancy, i.e., different levels of softness. This is a vital function to mechanical metamaterials. Most compliant metamaterials are based on 2-dimensional structures. This is great for mimicking simple and linear mechanisms, but is not as suitable for more complex systems. A 3D metamaterial structure could potentially solve this bottleneck. Although this is mostly hypothetical right now, I am researching the concept.
Links:
Thingiverse: http://www.thingiverse.com/thing:1778238
