• V2 much nicer
    Jeremy g.04/20/2018 at 23:09 0 comments
    V2 turned out much nicer, if using an rj45 cable like I did take all the other wires out except the two you are using and push back the material, makes installing the female header much easier.
  • V1 printed, and works.
    Jeremy g.04/20/2018 at 21:56 0 comments
    some pictures of v1 in use, v2 is printing now. There are spaces for 3mm zip ties. Had to use some hot snot.
