V2 much nicer
04/20/2018 at 23:09 • 0 commentsV2 turned out much nicer, if using an rj45 cable like I did take all the other wires out except the two you are using and push back the material, makes installing the female header much easier.
V1 printed, and works.
04/20/2018 at 21:56 • 0 commentssome pictures of v1 in use, v2 is printing now. There are spaces for 3mm zip ties. Had to use some hot snot.
