PlugAndLive (part 1)
10/03/2016 at 10:41 • 0 commentsNow that we start to have a couple of modules, somehow we have to put them talking with the system.
For that one of the modules requirement is that we have protocol to which all modules have to abide.
This protocol that we will start calling PlugAndLive will have at least the following constituents: Presentation and Vocabulary.
In the Presentation part the module announces its name to the server, so that the server can uniquely identify it.
In the Vocabulary part, the module indicates which events and methods it responds to.
As we can see in the following printscreen, the server enumerates all COM ports searching for connected arduinos and in case it finds one, it try to establish communication with the module.
Let's shed some light (Part 1)
10/02/2016 at 10:00 • 0 commentsOne of the most commonplace in IOT and automation is the ability to turn on or off
electrical appliances.
So we had to create a module that could give the users of the system that power.
But before we put our hands on it, a disclaimer:
Dealing with electric power is dangerous, so do not do it unless you are 100%
sure about what you are doing, and a word of caution: disconnect always the cable
from mains power before messing inside the module.
For this project we are using a plastic case based system that is popular in Europe
for delivering cabling systems inside buildings. Two of most common brands are the french
Legrand and the portuguese Efapel. They are somehow compatible and in this particular
assembly we are using elements from both brands.
Legrand is more widespread and has power sockets that comply with standards for several countries.
Once again, we try to have an assembly that is straightforward to build.
The main components are an Arduino Uno and a board with a pair of solid state relays.
They do not stand too much power (theese are rated 2A). So they can drive lights, but are not
suitable for appliances that consume more power like heaters.
Their advantage is that they do not produce electric interference when they are activated or
deactivated. We plan to build another socket with electro mechanical relays, but for that we have
to add some electromagnetic filter.
It takes a big button to send an email (Part 2)
09/28/2016 at 10:34 • 0 commentsFrom the point of view of the software, to develop the solution, we are using Visual Studio Community Edition that can be freely downloaded and used for noncommercial purposes.
To build up this configuration (push a button to send an email) it was created a command line executable that accepts some parameters and send an email.
The application is still being developed and as we add more features will be adding more details in future logs, but for now we can say that for the purpose of this demonstration, we created a script inside the application that instruct the system that when a “button pressed” event is detected it will fire a command that will send an email.
It takes a big button to send an email (part 1)
09/25/2016 at 18:17 • 0 commentsIn this first assembly, we will see how a user can interact with the system using a simple button.
For that we will create a script that instructs the system to send an email when a button is pressed.
We chose to use a big dome push button, because we have in our family a person that suffers from arthritis (or arthroses) and have trouble to press small buttons.
In this construction (as in others that will follow) we will try to keep them as simple as possible.
We chose components that are readily available and that require the minimum hassle to mount as possible.
This setup will be done in two steps.
In this log we will look at the hardware side, in a second log we will handle the software.
The main components of this module is an Arduino Uno and a big dome push button.
We will give a final touch mounting all the components inside a plastic enclosure.
The skills required to build this module are the ability to drill some holes in the plastic case and soldering a resistance. This last is necessary because we want to give some user feedback and light up an LED that is built in in the push button.
The tools required are a crimping tool, soldering iron and a screw driver.
It is used a USB cable with a panel fixed socket so that we can close the enclosure and still communicate with Arduino.
