update
A project log for reCLOCK
retro LED clock
alexAlex 03/29/2017 at 16:280 Comments
This project is still ongoing and I did received the PCBs some time ago. I also started soldering and programming. Here a picture of the line driver section of the PCB:
I also got a little bit into trouble with the LEDs. Some how I placed them all in the wrong direction in the schematic. So that the cathode marking on the PCB is now an Anode marking. The really bad thing is that I noticed that after soldering all LEDs the wrong way around.
During the first programming/debugging secessions I also made this test pad overview:
