# sinelut
Command line Sine look-up table generator
GitHUB link: https://github.com/MightyDevices/sinelut
Simple software that allows to create sine/cosine valued LUTs to be created. Perfect for testing audio signal paths involving Digital to Analog converters.
# How to build
gcc -o sinelut.exe -lm sinelut.c
Nothing more, nothing less.
# Usage
This command line tool accepts quite a few parameters:
- -n number of array elements (**required**)
- -a amplitude (default - maximal amplitude for given output bit width)
- -p sine period expressed in number of elements
- -s sine starting angle (relative to period, default: one full period in output buffer)
- -o additional offset (added to every sample, default: 0 (zero-centered sine))
- -b bit width of a single array element (8 (default), 16, 32)
- -l number of elements per line (0 - single line output, default: 8)
# Examples
Ex. 1: **Generate a sine array that has 100 byte elements**
Input:
sinelut.exe -n 100Output:
0x00, 0x07, 0x0f, 0x17, 0x1f, 0x27, 0x2e, 0x36, 0x3d, 0x44, 0x4a, 0x50, 0x56, 0x5c, 0x61, 0x66, 0x6b, 0x6f, 0x72, 0x76, 0x78, 0x7b, 0x7c, 0x7d, 0x7e, 0x7f, 0x7e, 0x7d, 0x7c, 0x7b, 0x78, 0x76, 0x72, 0x6f, 0x6b, 0x66, 0x61, 0x5c, 0x56, 0x50, 0x4a, 0x44, 0x3d, 0x36, 0x2e, 0x27, 0x1f, 0x17, 0x0f, 0x07, 0x00, 0xf9, 0xf1, 0xe9, 0xe1, 0xd9, 0xd2, 0xca, 0xc3, 0xbc, 0xb6, 0xb0, 0xaa, 0xa4, 0x9f, 0x9a, 0x95, 0x91, 0x8e, 0x8a, 0x88, 0x85, 0x84, 0x83, 0x82, 0x81, 0x82, 0x83, 0x84, 0x85, 0x88, 0x8a, 0x8e, 0x91, 0x95, 0x9a, 0x9f, 0xa4, 0xaa, 0xb0, 0xb6, 0xbc, 0xc3, 0xca, 0xd2, 0xd9, 0xe1, 0xe9, 0xf1, 0xf9
Ex. 2: **Generate a cosine array that has 16 16-bit elements**
Input:
sinelut.exe -n 16 -s 4 -b 16Output:
0x7fff, 0x7640, 0x5a81, 0x30fb, 0x0000, 0xcf05, 0xa57f, 0x89c0, 0x8001, 0x89c0, 0xa57f, 0xcf05, 0x0000, 0x30fb, 0x5a81, 0x7640,
Ex. 3: **Generate a sine (with a single period of 8 samples and amplitude of 1000) in 64 element array that has 64 32-bit elements. Add an offset of 10 to every sample. Format the output so that it has 4 entries per line.**
Input:
sinelut.exe -n 64 -p 8 -a 1000 -b 32 -o 10 -l 4Output:
0x0000000a, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x00000009, 0xfffffd47, 0xfffffc22, 0xfffffd47, 0x00000009, 0x000002cd, 0x000003f2, 0x000002cd, 0x0000000a, 0xfffffd47, 0xfffffc22, 0xfffffd47,
Tomasz
Bruce Land
Michele Perla
