Hackaday.io Hackaday.io
Sign up Log in
Mitochondrial DNA Scale Model
Educational Artwork
oneohmoneohm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
  • The 2016 Hackaday Prize
View Gallery
438
0
5
3
Team (1)
  • oneohmoneohm
Join this project's team
completed project
2016HackadayPrize
This project is submitted for
  • Hackaday.com Tip Line
  • Assistive Technologies
This project was created on 09/23/2016 and last updated 7 years ago.
Description
For less than $200 you can have your full mitochondrial DNA sequenced. Cool! Staring at the resulting text file on a computer monitor is a bit lackluster however... How about a physical scale model? 16,570 hand strung 1 mm glass beads joined in a loop - The beaded pattern corresponding exactly to the base pair sequence. Painstakingly checked and rechecked for accuracy. This strand exactly replicates my personal mitochondrial DNA sequence. Different colors represent the base pairs. White - Guanine ~ 2169 beads Purple - Adenine ~ 5124 beads Green - Cytosine ~ 5181 beads Orange - Thymine ~ 4094 beads A relaxed mtDNA strand has a length of about 5.61 Micrometers (~16,500bp*340 pm). The finished beaded sequence is close to 60 feet. => 3 million times larger than the actual mtDNA loop.
Components
  • 3 × TOHO Round Seed Bead 15/0 Purple Lined Aqua (8g packs) http://beads.artbeads.com/jewelry-supplies/Tbrd15--252
  • 2 × TOHO Round Seed Bead 15/0 Opaque White (8g packs) http://www.artbeads.com/tbrd15-41.html
  • 3 × TOHO Round Seed Bead 15/0 Transparent Medium Green (10g packs) http://www.auracrystals.com/products/toho-round-seed-bead-15-0-transparent-medium-green-10g-15-7b
  • 2 × TOHO Round Seed Bead 15/0 Transparent Medium Orange (10g packs) http://www.auracrystals.com/products/toho-round-seed-bead-15-0-transparent-medium-orange-10g-15-10b
  • 1 × BeadSmith Flex-Rite Beading Wire, 49 Strand .018" Thick, 100 Foot Spool, Clear https://www.amazon.com/gp/product/B00TYWM3LO/
View all 7 components
Project Logs
Collapse
  • Wrapping up
    oneohm • 10/03/2016 at 04:41 • 0 comments
    The completed sequence - before joining the ends. Mitochondrial DNA is actually a ring-structure.
  • The Pattern
    oneohm • 10/03/2016 at 04:36 • 0 comments
    The colors correspond to the binding energy of the base pairs - I made a macro to color the cells and mark them off as I progressed - Always double checking each segment.
  • The Materials Assembled
    oneohm • 10/03/2016 at 04:31 • 0 comments
  • The raw data for my mtDNA sequence
    oneohm • 10/03/2016 at 04:24 • 0 comments
    Fascinating intellectually, but a bit dull for the senses.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Collate forearm muscle soreness data on the SD card, build and train a neural network model, and run the model directly on Wio Terminal.
Project Owner Contributor
Mouse Fatigue Estimation by GSR & EMG Values w/ TF
kutluhan-aktarKutluhan Aktar
A concept for a small RPN processor with interesting features
CPU7
knvdKn/vD
A tutorial on parametric designing with Autodesk Fusion 360.
Designing a Parametric "Print in Place" Hinged Con
greg-zumwaltGreg Zumwalt
Perform machine learning on sequential (timeseries) data using a recurrently weighted average model
Recurrent Weighted Average Model
jared-jostmeyJared (jostmey)
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Mitochondrial DNA Scale Model ", please tell us the reason.
Send message
Remove Member
