I have finally created a clear circuit diagram using the Fritzing circuit creator software. I will add this to the instructions. Please note this is the circuit schematic for version 1 of the Minder smartwatch. Also some of the parts were unavailable on the software so I used generic boards to represent them (eg: OLED screen).
Also the RGB leds are already on the Qduino board, they need to be removed by de-soldering them off the board and delicately using small pliers to pull them off. Alternatively you could buy separate RGB leds, but why not use what's already there? : )
