Light Painting
Handheld wand for light painting on long exposure photos
Arduino based light painting box wand (although it looks more like an unfinished Sci-Fi prop...)
The idea was to give a bit more freedom with the motion of the light bar, and delay between columns. As with all my projects most of the parts for this are recycled, which is why it looks like a 60s sci-fi prop. Hopefully if this works ok, i'll move it to a r-pi with full PWM RGB LEDs to give a greater range of colours.
And we're off again.... hopefully all the soldering is done now.
  • Finally tested properly
    sad_ken09/28/2014 at 20:16 0 comments
    After many months i finally got to test the POV wand!! some of the pictures are below:
  • Almost Finished
    sad_ken06/26/2014 at 09:21 0 comments
    Sadly no photos yet, but i've got everything wired up, and enough coding done to make it fully operational (although i could do with adding a mode to vertically flip the image...).
    Interesting side note:
    I'm currently testing it with a 24 x 1024 repeating version of this image...
    when running the light wand at the right speed, and waving it back and forth like a nutter (only current way of testing the image) you get an animated fire effect.  Could be the start of a new sub project....
  • Shift Registers Working
    sad_ken06/24/2014 at 07:47 0 comments
    After finally finishing the soldering, I borrowed an Arduino Uno from another project, and wrote a quick test program.  Amazingly all the LEDs lit as they should (if you could see the mess of wires inside you'd be impressed!).
    Due to the lack of a camera with long exposure setting, i had to photoshop together a couple of images, but it gives you a good idea of what it'll look like.
  • finally overcame the laziness and soldered all the leds. next step some basic arduino test code.
    sad_ken06/22/2014 at 20:48 0 comments
View all 4 project logs
Adam Fabio wrote 06/24/2014 at 17:03 point
Glad you got your LEDs soldered up, and are seeing your first letters from the light painter! Can't wait to see the pictures you come up with.
sad_ken wrote 06/25/2014 at 07:46 point
Thanks :) It's pretty limited as i didn't have any RGB LEDs kicking around, but hopefully it'll serve as a good start for a bigger project.
