Spoonful
An automatic assistive feeder which can make someone have a meal.
6 million people in India suffer from different locomotive disorders and there are no available technology to assist them. This hampers their day to day activities and one of most important would be having a meal independently. The specially challenged find the day to day tasks challenging and need to depend on others. People derive confidence from their sense of independence in the society. This solution empowers the differently able to have their meals independently anywhere, bridging the gap between technology and disability.
Various attempts have been made to provide a feeder device which will assist or
help the physically disabled individuals to have their meal independently and
these devices are bulky and hence needs to be affixed at a single position and
cannot be carried from point to point where the patient/ physically disabled or the
end user is located.
US3907126 discloses a feeder apparatus for physically handicapped persons.
US5282711 discloses an assistive dining device, system and method for automatic
self operated self feeding.
Prior Art Research
1:
These existing devices and many more are bulky. Although these devices are essentially going to replace a personal caretaker, the user is still dependent on them. Here are few devices which take a different approach on taking on this challenge. These devices apart from feeding also act like as exoskeleton, building on the muscle memory.
Stable Slide Self-Feeding Support
LIFT-WARE
A lot of people relate this to liftware (now a Google owned company) helps stabilize unwanted hand tremor from Essential Tremor or Parkinson's Disease. Therefore this doesn't address to cerebral palsy
Another video which people can relate to is the one from this movie.
Spoonful_Docsv1.docx
The doc gives a detailed version of prior art search and describing different parts
document - 1.23 MB - 09/27/2016 at 14:30
Download
  • 4 × Limit Switch To limit the motion of the spoon
  • 2 × 9v 3.5 rpm DC Motor To scoop food out of the bowl
  • 1 × Stepper Mootr To help rotation of bowl
  • 1 × Arduino Micro
  • 2 × L298N Dual H-Bridge Motor Driver 1 driver for 2 DC Motor, second one for stepper motor
  • Functioning & Calculations
    Ayushman Talwar09/24/2016 at 18:12 0 comments
    TORQUE CALCULATION
    MOTOR 3
    MOTOR 2
    MOTOR 1
    Product Specifications
    Height Adjustment
    2 Feet ( Automatic )
    Distance from stand
    1.5 Feet
    Battery Life
    4 Hours
    AC supply
    220-230 V
    Current Required
    2-3 A
    Food Volume
    1.5 Liters
    Food Types
    Semi-solid
    Sensor to prevent spoon hitting the teeth
    Yes
    Total Weight
    2-3 Kg
    Device Height
    10 Inches
    Device Diameter
    14 Inches
    Legend No.
    Legend Description
    1
    Base
    2
    Upper rim of the base
    3
    Rotation Adjustment
    4
    Channels for distance adjustment
    5
    Motor for rotating the bowl
    6
    Bowl
    7
    Motor for guiding the spoon to scoop the food
    8
    Motor forspoon movement
    9
    Spoon
    10
    Haptic Feedback Button
    11
    Battery Pack
    12
    Cross scissor lift
    13
    Electronic housing
    14
    Camera
    15
    Level 1
    16
    Level 2
    17
    Level 3
    18
    Assistive feeder device
    19
    220-230 V plug
View project log
