1Arduino sketches
Adding a sign
float _raw;float _data;
bool sign;
float Volt;const int polarity = 7;
void setup() {
Serial.begin(115200);
pinMode(polarity, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
}//TODO two's compliment in asm
void loop() {
sign = digitalRead(polarity);
_raw = (float) analogRead(A0);if(sign) {
//_data = _raw * -1.0;
Volt = _raw * (-5.0 / 1023.0);
digitalWrite(LED_BUILTIN, HIGH);
} else {
//_data = _raw * 1.0;
Volt = _raw * (5.0 / 1023.0);
digitalWrite(LED_BUILTIN, LOW);
Serial.println(Volt);
Increasing Vertical resolution:
#include
#define ADC1 (0x90 >> 1)
#define ADC2 (0x92 >> 1)byte v0,v1;
int adcSum;
void setup() {
Serial.begin(9600);
Wire.begin();
Wire.beginTransmission(ADC1);
Wire.write(0x40);
Wire.endTransmission(false);Wire.beginTransmission(ADC2);
Wire.write(0x40);
}void loop() {
Wire.requestFrom(ADC1, 1);
v1 = Wire.read();
Wire.requestFrom(ADC2, 1);
v2 = Wire.read();adcSum = v1 + v2;
Serial.print(v1);Serial.print(",");
Serial.print(v2);Serial.print(",");
Serial.println(adcSum);
Gintaras Valatka
