Alternate IMU data filtering
11/21/2018 at 21:10 • 1 commentContinuing to tinker with my IMU fusion code. I'm currently playing with improving the data cleaning before the calibration process. In the ideal world (where calibration isn't necessary) the vector length of each point would be equal. Obviously that's not the case (and it part of what calibration is trying to achieve), but eliminating vector lengths with extremely small or large values seems like a good approach to removing outliers.
_filterPoints: function(points) { const sqlengths = points.map((point) => { return point[0] * point[0] + point[1] * point[1] + point[2] * point[2]; }); const mean = MATH.mean(sqlengths); const std = MATH.std(sqlengths); const low = mean - std; const high = mean + std; const fpoints = points.filter((point, idx) => { return sqlengths[idx] > low && sqlengths[idx] < high; }); return fpoints; }
The above code does just this and, in some limited testing so far, seems to produce a more accurate and stable quaternion result.
Good software IMU with data fusion
11/20/2018 at 05:48 • 2 commentsOne of the single most expensive components on the Module board is the BNO055 IMU. In single quantities it costs $12 (https://www.digikey.com/product-detail/en/bosch-sensortec/BNO055/828-1058-1-ND/6136309). I, like many others, chose this chip because it has two very appealing qualities - it self calibrates and outputs quaternions. This avoids lots and lots of math on the host CPU; math I mostly don't understand.
However, as I look at moving this module board towards production, the cost of this chip annoys me; especially when I'm designing various projects which don't immediately need an IMU. It increases the BOM costs substantially, while offering little immediate gain.
Because I do want an IMU on this board, I've begun to look at alternatives. In that process I realized the only way to decrease the cost is to do the math on the PI.
There are three sets of math that must be done for a good software fusion IMU:
- Calibration - which turns the raw noisy sensor data into something more repeatable.
- Cleaning - to eliminate poor sensor readings
- Operation - turning sensors readings into usable rotations/quaternions
Calibration Math
I've taken a stab at IMU calibration math a couple of times before and ended up abandoning the efforts as the results were not good. There are lots of algorithms which attempt this process, and many of them appear to assume IMUs are far better behaved than they actually are. I eventually found this calibration explanation (https://thecavepearlproject.org/2015/05/22/calibrating-any-compass-or-accelerometer-for-arduino/) by the Cave Pearl Project which uses this tool (http://sailboatinstruments.blogspot.com/2011/09/improved-magnetometer-calibration-part.html) by Sailboat Instruments. Essentially a set of raw datapoint are gather from the magnetometer and accelerometer (each set form an elliptical shape) and maps them into a sphere centered on an origin. The Sailboat tool (Magneto - https://sites.google.com/site/sailboatinstruments1/home) generates this as a vector translation and matrix transformation.
While the Cage Pearl article discusses doing this analysis offline (they're using Arduinos which are not up to the online math), they include a C implementation of their algorithm; one quite capable of running on a Pi.
Calibration Cleaning
Just feeding a large set of values to the calibration algorithm will not necessarily get the best results. Ideally you need many points from all orientation of the IMU in order to get the best transformation. Also, because IMUs are noisy devices, they generate outlier values which can confuse the calibration algorithm.
So it is necessary to clean the calibration data before using it to calibrate. To gather a "good" set of points, each point is translated from (x,y,z) form into spherical coordinates (inclination, azimuth); think of this as the longitude and latitude of the point on the surface of a sphere. We divide the surface of the sphere up into a number of "buckets" of approximately equal area, and place each point into the appropriate bucket. The goal for good calibration is to sample enough points and place a minimal number into each bucket.
One the buckets are full, we must eliminate any outliers before passing the points for calibration. Outliers are consider to be any point where an (x,y,z) value is outside 2 standard deviations of the mean. Once removed from out dataset, the resulting points generate excellent calibration data.
Operation Math
Using the calibration data, we can now adjust the IMU's raw values to make them usable. However, we still need to turn this data into a quaternion. A quaternion is a 4-dimensional vector which is used here to represent the rotation of an object (https://en.wikipedia.org/wiki/Quaternions_and_spatial_rotation).
The best algorithm I found to handle this process is by Sebastian Madgwick (http://x-io.co.uk/open-source-imu-and-ahrs-algorithms/). It takes (x,y,z) inputs from the three IMU sensors (accelerometer, gyroscope and magnetometer) and generates a quaternion (w,x,y,z). The algorithm runs in a loop, with inputs constantly updated in a predicable, period way. The faster the loop, the more sensitive the quaternion to changes in the position of the IMU.
Implementation
My final implementation is a combination of Javascript and C. The C code handles all the heavy math, while the Javascript does all the data management. Calibration is automatic; the code gathers calibration points continually and adjusting the calibration as necessary. This means that once calibration is established small changes in the environment, which might effect the sensor readings, should be compensated for. Calibration data can also be saved and restored, so re-calibration on startup need only be done when absolutely necessary.
Results
For experimental purposes I've been using an old LSM303DLHC+L3GD20H board (https://learn.adafruit.com/adafruit-9-dof-imu-breakout); I think it's discontinued now. This already generates pretty good data and, unlike some other IMUs, the axises are all aligned. Having different sensors with different axises alignments isn't the end of the world, but trying to wrap my mind around how to adjust things has proved ... difficult.
The results from my tests have been excellent and probably more stable than the BNO055 which tends to loose calibration randomly. I'm not sure I expected to end up with a better sensor at the end of this process, but that's what I got.
Which IMU?
I'm now at the point that I need to choose my final, replacement IMU. Cheap is important. It should cost no more than $6 (1-off quantities), preferably less. But it also needs to have great repeatability and low drift because software correction can only do so much with noisy data.
If anyone has any recommendations, please let me know.
Network configuration
09/30/2018 at 23:48 • 0 comments- WiFi - the wireless connection to a local wireless network (e.g. your home network)
- AP - an access point network allowing you to connect directly to the module (for when you're not at home)
- Ethernet - a wired network if the module detects a USB ethernet device has been connected.
By default the AP network is the one you might use to first configure the board as the network name is visible to any WiFi scanner and the password is well known. From there you might reconfigure that network, or connect the module to your local network (which just makes everything a little easier for later development).
The ethernet configuration defaults to serving addresses to whatever connects to it; ideal for just plugging directly into the ethernet port on a laptop. However, it the address is switched to DHCP it will instead act like any other client device on a shared network, soliciting an address from your local DHCP server.
UI Designer
09/23/2018 at 04:47 • 0 commentsThe photo above shows V1 of the UI Design tool. This lives under the UI tab in the Blockly code editor which is already part of the Module's software stack. The Designer has three basic parts:
- Virtual screen - the hatched space onto which tools can be arranged. Controls "snap" into place, which helps them move and scale depending on the size of the phone's screen.
- Properties - the properties of the current selected control allowing customization
- Controls - the periodic table-like set of controls which can be arranged on the screen.
The design pictures shows a fairly basic arrangement: a 2-axis joystick (on the right) for robot control, a title (top/left), a meter (bottom/left) displaying the battery health, and behind everything a camera feed from the robot. When displayed on the phone it looks like this:
The controls themselves, once on screen, export their APIs by creating new Blocks in Blockly. Controls can either provide information (e.g. the current x,y location of the joystick), accept actions (e.g. setting the battery level) or both.
Here is a snipped of the code to run the robot. Two blocks configure the camera and battery chemistry. The final block runs an activity which uses the current battery health (0-100%) and set the level of the meter in the UI (which you can see on the phone screen).
Improvement
This is the first version of the UI and there are obvious improvements:
- Expand the controls available and make them more customizable.
- Design more appealing controls! What I have here is pretty basic; it would be good to find some design help to make this all look more polished and professional.
Camera streaming @ 100ms, ethernet edition
09/15/2018 at 01:26 • 0 comments -
Camera streaming at 160ms
09/11/2018 at 05:24 • 0 commentsFor some reason, streaming video from a Raspberry Pi camera across a network to a web browser is unnecessarily difficult. You'd think it'd be easy enough to pop a URL into a video tag and all would be great. But obviously it's more complex than that. Once you've factored in video formats, container formats, streaming formats, and the matrix of these which your favorite browser might support, it all just seems a bit broken.
Over the years I've tried many things to get this working, including wrapping mpeg4 video in streams only Chrome supports ... until it doesn't; or repurposing ffmeg to generate content which everything supports, but kills the cpu on the robot in the process. And it all kind of works until you start to notice that the video latency can just make it all unusable anyway. It's difficult to control an ROV when the video latency is a couple of seconds.
So ultimately everyone falls back to the simplest thing - Motion JPEG. Motion JPEG is a sequence of JPEG images, formatted as a multipart HTML stream, which any browser with an IMG tag will display. One popular application for generating these streams is GStreamer, but GSteamer can do a lot more than just push JPEGs across a network, and for my purposes it's big, ugly and unnecessarily complicated.
So, time to write my own.
The new Camera app landed in 8BitModule GIT today and it's the simplest thing. On one end it reads JPEGs directly from the Raspberry Pi camera using the V4L2 interface, and on the other a super simple web server pushes these images across the network to whomever wants them. And that's all it does.
One other reason to write my own Camera app is to manage cpu and latency. The first cut of the app had a latency of 1.5 seconds ... which was a bit depressing. But after lots of experimentation (and experience from my various other attempts), the app come pre-configured to deliver latency of about 160ms over WiFi (see the photo above - the top browser is displaying the video of the timer at the bottom). It does this in a few ways. First, the JPEGs are always 1280x720 which appears to be the optimal size. Second, it reads frames from the camera as fast as the camera provides them (which happens to be 30 fps). Finally, it send these images across the network at 60 fps regardless of the speed of the camera (the camera side and website run in different threads). The result is a stream with minimal latency and only consumes 18% of the Raspberry Pi Zero cpu.
Why these values are the sweet spot I don't know. If anyone understand the latency of moving an image though a web browser and onto the screen I'd love to understand that. Delivering too few images to the browser seems to increase the latency, but why is that?. Is it possible to get more fps from the camera without a major hit on the cpu? Ultimately, where does that 160ms go? I'd love to know.
PIDs v2
09/03/2018 at 18:06 • 0 comments- PIDs now have a type - either linear or circular. A linear pid is how you might imagine, with the PID attempting to reach the setpoint assuming the input value is on an infinite number line. The circular pid assumes the setpoint is an angle on a circle (so between 0 and 360) and internally manages the discontinuity where 359 is close to 0. These types of PID are useful for managing navigation and continuously rotating servos.
- Setpoint and Input - rather than the user calculating the difference between the desired outcome (setpoint) and the current outcome (input) to provide the PID with the different (error), the PID now takes both values separately and manages the error internally. This allows for smoother operation, especially when the setpoint changes quickly.
- Time-based - The I and D values effect the PID output based on time. The original PID assumed it was being called periodically while the new PID handles being called more sporadically.
PIDs
08/24/2018 at 00:27 • 0 commentsOne fundamental software piece for any robot is the PID controller - the Proportional Integral Derivative controller (see https://en.wikipedia.org/wiki/PID_controller). Adding one to the RoBonnet software stack was always a given. In fact, the software stack has had such a controller for a while, but I've now had chance to provide access to it via Blockly:
Many PIDs can be created, named, and configured with the setting you'd expect to find. I also added a couple of extras to define a "neutral zone" where the PID output is clamped to zero, and limits to clamp the outputs to low and high values.
The following simple control program configures the Rolling Robot Ball to always return to a specific heading (determined by the RoBonnet IMU).
And you can see the program in action in the video below:
ESC Configuration - Take 2
08/17/2018 at 18:26 • 0 commentsAfter some experimentation with the first ESC configuration, it turned out that simply controlling the maximum rate the motor velocity changed was not quiet enough to stop it resetting when rapidly switching from forward to backward; I needed to add a "pause at neutral" time as well.
The new configuration, seen above, is very like the pervious one except now there's a "rate change base" which controls the fastest rate at which the velocity can change, and a "neutral transition" time which pauses the motor - momentarily - when passing through neutral.
Of course, I'm testing these values running my motors in air when they will ultimately be running in water. Given that, I expect I can decrease the rate and neutral times to improve robot responsiveness once everything gets wet.
ESC Configuration
08/13/2018 at 18:44 • 0 commentsESCs can be easily attached to the PWM pins on the RoBonnet. However, there's a bit of software configuration necessary to make them useful.
Above shows the basic configuration of an ESC Part. The ESC can be configured to have a maximum forward and backward pulse width (in milliseconds) as well as a neutral range - this can vary depending on the ESC being used. In this example the ESC can drive the motor both forwards and backwards although different parameters can be set if the ESC is forward only. A toggle is also provided to switch the ESCs notion of forward and backward which can be useful if the attached motor is reversed (as can often be the case with two-wheeled robots). Finally, a direction change limit is provided. If you've ever tried slamming an ESC motor from forward to backward without going through neutral you'll know how bad an idea this can be (often causing the ESC to reboot or simply fail). This final setting limits how fast this change can be effected to prevent failure.
The "Setup" block shows how the ESC can be managed once configured. A velocity between -1 and 1 is translated by the ESC software into the appropriate motor motion based on the configuration. Here the motor velocity is just being set to zero which most ESCs require as part of their initialization.
