Laser Beacons Replaced with IR LEDs
A project log for Low Cost Open Source Eye Tracking
A system designed to be easy to build and setup. Uses two $20 webcams and open source software to provide accurate eye tracking
john-evansJohn Evans 10/22/2018 at 10:560 Comments
In order to provide a reliable and non intrusive experience to the user, the beacons used for the ransac approximation were switched from a red laser diode based design, to IR LED's at 940nm.
Additionally an IR filter was added to the front facing camera. Changing the front camera output from a typical camera output, to a tool to be used for localization and mapping.
