Testing (with music)
08/19/2015 at 15:54 • 0 commentsA 1 minute Shower
Printable Case Desing V1.0
08/21/2014 at 05:52 • 0 commentsFirst Really simple Printable Design *skecthup (in Desing Github Project)
Found A Great Board (robotics) to replace Blueduino
08/20/2014 at 07:42 • 0 commentsFound a Great Robotics board that would do to replace loose components... includes BLE, Dual H-Driver 1.2A, O/OFF Switch, Lipo Recahrger circuit, plus separate IR detectors for gesture control and additional GPIO Available. all fo $49 USD cheap.
Changed Arduinos
08/20/2014 at 07:20 • 0 commentsChanged from Pro Mini 328p 3.3V/8MHz to Pro micro 5V/16MHz with HM-11 BLE module integrated on board the same PCB for Space Restrictions
Prototype Rev.B
08/20/2014 at 07:18 • 0 commentsTested New Code to reset The millis() counter in Arduino code, so as to prevent overflow of data after clock is started and board is not reset in 9 hours... or so...
Kestler
