HWRE V1.1
A project log for Hardware Reverse Engineering Learning Platform
a hardware version of your crackme and reverseme games for learning hardware reverse engineering techniques without expensive tools
tom-van-den-bonTom Van den Bon 07/22/2014 at 16:580 Comments
So haven't managed to keep my logs updated as much as I would like to. With regards to the previous pcb, they are up and running although they do have a few small mistakes and also a few things I didn't like, so I spent a few hours updating the pcb. (I'll take some photos of the assembled board with a more detailed post on what exactly is wrong and what I added to the new boards)
I present to you HWRE V1.1
As you can see I'm also using this as a test for some graphical stuff. Not sure yet if the fabhouse will accept it, but we'll see ;) Still need to do some checks, but will be sending these boards away for fabrication in a few days :)
On the software side, I'm making good progress. Will be posting what/where and how in the next couple of days :)
