PCBs arrived from manufacturing
A project log for RC2016/99: TI-99/4A clone using TMS99105 CPU
Retrochallenge 2016/10 entry and winner: try to build a TI-99/4A clone using a TMS99105 CPU and an FPGA. In a month...
erik-piehlErik Piehl 12/20/2016 at 07:550 Comments
It is always a great feeling to get the physical boards from manufacturing :)
I had no real time to check the boards, but on the surface they seem fine. At least the connector measurements turned out ok and the board perfectly connects to the Pepino FPGA board.
The top of the board, photo taken through my magnifying glass / light:
Bottom side, with connectors mounted (no time yet for anything else):
A close up of the connection to the Pepino, it appears the SD card and audio jack are still accessible:
