HealthMon
A wearable temperature and heart rate monitor for sick children that alerts parents via bluetooth if either gets too high.
HealthMon is a ATtiny85/84 based wearable device that allows parents to monitor a sick child's temperature and heart rate remotely via a bluetooth app on the phone.
Strapped to the arm the probes attach to the under arm to provide the inputs. An OLED display allows you to see the current values without having to wake/move the child. Device it battery operated.
Updates are sent from the device via Bluetooth to a connected phone, which will alarm the user if either the temp or the heart rate exceed alert values.
POC device uses an ATtiny85 with an SSD1306 128x64 OLED display.
Temperature probe - TMP36
Heart Rate - piezoelectric sensor
Full version will use an ATtiny84 to allow addition of bluetooth to allow the device to update to a connected device.
  • 1 × attiny84 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × tmp36 Sensors / Temperature, ThermalTem
  • 2 × 10uf capacitor
  • 1 × SSD1306 128x64 OLED display.
  • 1 × cr2032 battery
View all 6 components
don.vukovic wrote 04/01/2020 at 01:38 point
Which Bluetooth device is used here ?
