Bite force sensor
A project log for The Bit
A tongue IO device
oneohmoneohm 08/27/2018 at 13:290 Comments
I added a conductive rubber pressure sensor to measure bite force.
This allows tracking to be enabled with light bite force, and registers clicks with a stronger bite.
The force sensor is connected to the 10K potentiometer to create an adjustable voltage divider that connects to an analog input pin on the Teensy 3.1.
