Beta Prototype
A project log for The Bit
A tongue IO device
oneohmoneohm 10/22/2018 at 07:350 Comments
After trying out several combinations, I decided on the following sensors for the beta prototype:
Optical surface tracking
Time of flight laser displacement
Barometric pressure+temperature
Differential force (front to back)
Partially Assembled:
Getting Closer:
Buttoned Up:
Top side (showing front and back force sensors):
The two force sensors form a voltage divider allowing one analog pin to effectively monitor both. (Idle output voltage is half full scale)
