SRI INTERNATIONAL patent
A project log for 2D actuator move micro robot in X/Y 2D space
Less than 10$ educational platform with micro magnetic robot (mBot), only 6 GPIO to move in unlimited X/Y 2D space
bobriciusbobricius 05/04/2018 at 13:103 Comments
Finally I found SRI INTERNATIONAL patent with description https://patents.google.com/patent/US8593016B2/en
My solution is little different, I am using another pattern for movements also my design is 3 phases uni-polar against they 4 phases bi-polar design. They design is very energy effective because they have levitating manipulators over
pyrolytic graphite.
I searching samples of pyrolytic graphite.sheets, but without success now.
Ed0 wrote 05/06/2018 at 15:15 point
The best source for pyrolytic graphite I have found is here.  https://www.kjmagnetics.com/proddetail.asp?prod=PG5
You can split it to the thickness that you want.  I also tried reproducing the SRI setup but had trouble with the magnets.  I got 0.25mm thick "N52" magnets (5x5mm) but couldn't get them to levitate.  I still need to break them down to the size used in the paper and try again.
bobricius wrote 05/04/2018 at 13:24 point
Yes, I asked Panasonic for samples, but they can not help. SRI use 0,5mm thick foil. Panasonic have 0,1mm max.
OK. is time tonight solder mosfets and test automatic movements :) and next I need order 0.6mm pcb board, on 0.8mm board bottom traces have very weak movements.
Ted Yapo wrote 05/04/2018 at 13:16 point
https://www.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=135626005
Sold as thermal interface sheets, but they may also have the desired magnetic properties
