Without the need to attach a temperature sensor to the heat block/spreader, much more compact options become available, I have selected a cylindrical ceramic heater to provide even, concentric heating of the filament.
Compact module with direct nozzle temperature sensing
I find that a 14 to 15 Joule pulse weld gives the best results. The welder is an Orion model 100c micro pulse TIG welder.
Neat ! Which cylindrical heater adapter are you using ?
It looks like the heater from the deltaprintr mini.
TriangleLabs also sold these for a while, but have discontinued the aluminium version.
They sell one with copper "core" (threads) now, but that one has the "nut" towards the nozzle with space for a thermistor.
Both are (were?) 24v/50W.
Ah I love the way you implemented the heat shield / "sock"
