1Nozzle Assembly Components
2Thermocouple preparation
3Closeup of balled and flattened thermocouple wire ends
I find that a 14 to 15 Joule pulse weld gives the best results. The welder is an Orion model 100c micro pulse TIG welder.
4Closeup of thermocouple welds on the nozzle
Three welds are used for each wire to ensure solid attachment.
5Welded Nozzle Assembly
6Ultra high temp ceramic adhesive to protect the weld
I formulated an ultra high temp silicate adhesive to protect the weld and prevent the fiberglass sleeving from fraying.
The general process is just to add aluminum oxide powder to a sodium silicate solution to make a thin paste, then add just a tiny bit of trisodium phosphate (targeting around 1% of the amount of aluminum oxide).
It needs a few hours to set then should be cured at around 150 degrees C to drive out any remaining water.
7Finished Nozzle
oneohm
